JimmyPlenderleith
- Joined
- Feb 24, 2023
- Messages
- 11
Have a 4ft x 2 ft, 4 Bulb, T12 fluorescent light fixture in my hanging ceiling. Its been there since we bought the house.
About a year ago, the lights started to dim on all four bulbs. I went out and replaced the ballast and the lights seemed fine for a bit, but after another month or two they began to dim again. Flipping the light switch off and on several times will sometimes get at least two of the bulbs to go full bright. Once you turn if off and back on again though, they are dim. I have replaced the bulbs several times. Sometimes they are bright when put in, other times just dull. It even appears as if the bulbs are being damaged (maybe?) as you can see some black on the ends after they are put in.
I will gladly provide any other information, but wanted to get an idea of what I should look into doing? Should I replace the sockets? I can check to see if they are shunted or non-shunted and order new ones, but I didnt want to waste the money if the issue is the entire fixture.
We have a new box of 36 T12 bulbs I really dont want to waste by replacing the fixture with something new, but if that is what I must do, so be it.
Your expertise is greatly appreciated!!
