weatherby460
Should I get 4mm or 6mm plastic for walls when putting insulation in a pole shed. It will be metal, then r19 insulation, then plastic, then metal wall liner for the walls.
Do I need plastic when installing cellulose insulation in the ceiling? I will be using the metal liner material also for the ceiling. thanks
