4x6 Horizontal Bandsaw Options
Dan V.
west michigan
Sawblade.com Trajan 125 variable speed. Love it, always have to go get it from my nephew who “borrows it”. Catch them on a sale.
Can you tell me about this saw? Looks "like" a lot of other similar saws out there but the Trajan is mo expensive. Reasons for that?
WagonHo!
Albuquerque, New Mexico
I don’t know about the others but this one cuts true angles with no oily mess. I upgraded the blade which was pretty good. My nephew builds gates and fences and he won’t go back to cold cut saw mess or grinders nor will I. It’s light fast and accurate. They went up quite a bit since I got it call them maybe they’ll make a package deal with free blades.
apereira123456
Inside
I would look out for a used Johnson Bandsaw, they sell for cheap and are very good saws that last forever but I also saw this Grizzly G9742 in Buffalo for $300, good price for a swivel head and hydraulic down feed control.
What is considered a good price for a Johnson bandsaw? There is one for sale near me that looks nice.
racecougar
Missouri
I don't know about catching fire, but I have heard of people burning out the motor because the blade got bound and they were not right there to see it happen. I'm not sure that this is an issue limited to the cheap bandsaws other than a better quality motor might be more tolerant of the overload. In theory most motors have a breaker or other fuse but this may be like the oil light in a car where by the time it comes on the damage has been done.
Although the saws will run unattended, I will do other things while it cuts but I never go far from them when running.
Agreed. The few examples that I've heard of burning up a motor occurred when the blade got hung up and the operator wasn't around the machine to correct the issue. I keep myself within 30' of the saw any time it's running as a rule, and I have never had an issue.
As others have said, my recommendation is to pick up a gently used HF saw for cheap off Craigslist or FB marketplace and just build a better/taller stand for it. It is a handy little piece of equipment to have on hand.
foghorn1966
N. Alberta
If you find a good used saw and are still worried about burning up the motor. change out the switch or add a manual motor starter switch with provisions for an overload.
soloz2
Western NY
I was looking at some options for adding overload protection. Bottom line is I'll always be in the garage when cutting, but I may not always have line of sight based on the setup of my garage. The stairs are in the middle and creates a C shape.
It seems most of the folks that have reported issues with fire had a HF unit so I will look at something a bit better. I also reached out to Wen and Grizzly. Grizzly as expected responded promptly and gave the codes they follow for specification, but have not paid to have the saw UL listed. Wen took about a week to respond and said the saw was ETL certified. I wonder if other manufactures just aren't adding certifications into the spec sheet now. It seems odd to me.
That makes Jet, General International, Wen, and Grizzly would likely be alright. Jet has the largest capability at 5" high as opposed to 4-4.5" for the rest. They are also the most expensive. It's hard to justify the $600-700 range when a Grizzly or Jet 4x6" mitering with downfeed control is $800-900.
I'm still looking for used saws and haven't found anything local. Can't cross state borders due to work regulations. (Well I could, but don't really want to pay to get COVID tested 3x afterwards if I could avoid it)
Home
Or for a couple of hundred bucks you could get a nice little power hacksaw. They cut straight, blades are cheap. Lots of them around. They aren't really much slower than a bandsaw and are much less fussy. I now have a medium and a small.
Yep, I have one very similar, if not the same. I like the fact it cuts slow and the blades are nice and thick with little deflection. I think I paid $125 for it.
whateg01
doo dah, kansas, usa
I've owned several 4*6 saws from hf to Dayton to a couple other brands. I've had them set up for different jobs so I didn't have to change one back and forth. They come up cheap on cl and fb frequently. For the price of new I could buy a couple used. I always figured unless I was spending real money on a jet or something i was going to have to put a little effort into it anyway. The thing to watch for on used is the condition of the worm gear. If it's in need of replacement you'll spend half the cost of a saw on it. I have a couple 7*12 saws now and they do well, but I do sometimes think of picking up another small see for some jobs.
I would suggest if you are going to make 45 degree cuts on the regular, make a fixture that clamps to the fixed jaw of the vise so you don't have to loosen it and then square it up again after. It makes it go much faster. I always had 45, 30, and 22.5 fixtures for my 4*6.
I've never experienced a need for overload protection. I have read of other people burning up motors but in the event a blade bound up on any of the saws I've owned, the blade popped off long before the motor would burn up.
Many manufacturers of all kinds of stuff are skipping getting their stuff certified. It costs a lot of money to have it certified. I see a lot of ***-compliant nowadays.
soloz2
Western NY
I've been thinking a bit more about mitering and while I haven't ruled out the 4x6 handsaws, I am considering a mitering version. I figure if I add a hydraulic downfeed adjustment to a jet I'll be in the same price range as one of the mitering versions.
I so came across the Hem Saw by Femi 782XL. It is a smaller, bench top model, but miters and is made in Italy. I'm intrigued by this as it's actually cheaper than the Jet 4x6. There's a few models similar and I might take a closer look at a few of them. I'm not sure if I'd miss the capacity moving to a smaller saw, or if losing the ability to walk away while cutting and doing something else would be a deal breaker for me or not. Has anyone compared one of the smaller bench top models like the 782xl to the more traditional 4x6 style?
BD1
north side
I guess you missed my post #15.
I posted about that saw from trick tools.
I know there's a discussion about it on Weldingweb
Smokeem
I’ve got the Wen version that is similar to this. I’ve liked mine and it has done everything I have asked of it. Biggest thing I’ve cut with it was 4” sch 80 pipe. Took a little while but it cut it. Maybe not as fast as the floor models but I really like the portability and also how the head swings for miters and not the vise.
tarbellb
Oregon
Hem Saws by Femi are considered one of the best in that category. This will likely check all the boxes you are looking for.
A little to much plastic on them at that price point, but they are still good saws.
soloz2
Western NY
Well, thanks for all the help. It was a tough decision, but I decided to go with the Femi 782XL. Not exactly what I originally had in mind, but I think it will work for my needs and has the deed bonus of being small enough it can sit on the shelf under my welding table or in a cabinet across the shop when not in use.
soloz2
Western NY
My Femi arrived and cuts pretty darn good right out the box. [emoji41]
WagonHo!
Good buy Solo and with the tilt table you’re golden! I tell you for it’s size it can’t be beat plus accurate as the 4 x 6. Did you purchase the table separate or included, Femi product?
soloz2
Western NY
It is the official Femi table. They also make a miter gauge for use with it. I didn't get the miter gauge as I'll see if I can use one I already have. Just haven't gotten that far yet.
I ordered the Trick Tools deluxe kit which included 2 extra blades and the table. Overall savings was only about $20 less than buying the table, saw and blades separately, but it was still a savings.
soloz2
Western NY
I have an asian knock off of the femi, wish i would of ponied up the extra cash for the real thing. Cant ever keep the slip clutch in adjustment.
You are the second person to say something similar today. Definitely reassuring I made the right decision in ordering the Femi.
