It's harder than all steels. Takes rocks or abrasives to scratch it...
This is SO misleading.
First off, being harder than steel does not mean that steel will not scratch it. I've worked around a number of light tables used for cutting with razors, and the tempered glass gets grooved and messed up much faster than normal glass.
Second, the tempering process leaves the surface softer than plain glass. So sand and dirt grit (like pumice) that would not scratch glass will scratch it.
Finally, a glass tabletop is a polished super glossy surface. EVERY SINGLE scratch will be easily visible and will be an eyesore.
Now if you were talking about a shower door made from 1/2" plain glass (not tempered), you could take a wet sander to the surface and frost it, and scratches would then not be so bad, though plain glass would be more susceptible to being broken by dropping something on it.
