5/16 wave in concrete floor
AuxWelding
I have a 5/16 inch wave occuring over about 2.5ftx5ft section on my garage floor. Is this common in garage floors? I'm about to have the floor finished with polyuria and wanted to know if I should have it corrected before going ahead with the coating.
Picture 1
Picture 2
Sumboodie
AK
We have waves in the warehouse at work that bottom out the forklift. Probably 2" in 5ft.
ConCretin
Central Maine
That is a pretty good dip. I can't tell how long your straight edge is but I'm guessing 6'? If you used a 10' straightedge, which is the typical standard for evaluating a slab, I suspect you'd be looking at a 1/2" gap. If I'm right, that's outside what most would consider an acceptable level of flatness. Ideally you're looking for no more than a 1/4" gap under 10' straightedge for a reasonably flat residential slab.
With that said, the path forward depends on your circumstances. Is your contractor bound by any particular standard? What are the chances you can get him to successfully improve the flatness of your slab? How bad will it bother you when your new shiny new coating makes the waviness look even worse?
A
AuxWelding
It was a 4ft level. From what I understand the dip was just over 1/4 in. It didn't seem with the effort to deal with it. I had the floor sealed. I notice it a lot less now.
