5/8" Hex Tee Handle
r_olson_06
SD
Does anyone know of a company that makes a 5/8" hex key in a tee handle? I looked online and I am drawing blanks.
davethorik
Norka, Ohio
Looks like Eklind and Bondhus top out at 1/2".
Found an outfit called Certified Insulated Products that offer insulated tools, they have an insulated 9/16".
Not seeing any 5/8".
Could you use a 1/2 ratchet with a 5/8" hex bit socket?
OccupantRJ
Eastern North Carolina
Never seen one. Largest I have used in that style was 3/8”. For one that size you could weld a T onto a standard L shaped wrench after cutting it off with an abrasive blade. Even a factory one would not be good other than for speed in running a bolt in or out. Not going to tighten much by hand with one with little leverage available.
R
r_olson_06
SD
Thanks for the heads up. Looking for these as an item that we well with manchines we manufacture. Would like a purchase part if possible.
