5/8" OSB 24" OC in the attic
paker
My attic has 5/8" OSB around the heater/AC/water heater. As I walk on it, I can feel flexing of the board. I searched this forum and learned 3/4" is recommended for 24" OC. Honestly, I am afraid of the board breaking under my foot. The board must have been there since the house was built in 1990's. Live with it? Add 3/8" plywood over it? Thank you.
matt_i
I have one better. My attic in my shop was sheeted with 1/2" ply @ 24" centers when I bought the house/shop. Superflex.
So I realized I had a couple of choices, rip it all out and add 3/4" or better, or add another thickness. I went for the doubler, I bought a fair number of tubes of construction adhesive which were put down in X/Z shape patterns, in order to build shear between the layers.
Its very acceptable now.
Kaizen
New England
Just add 3/4 on it if it makes you feel better. No sense ripping it out
finn
The UP, God's country
Is this a floor you walk on every day or for storage in a typical attic, where you access it every few months?
5/8” is used on roofs with 100-120 lb/sf snow load rating with 24” truss spacing every day.
In fact, they used to specify 1/2” for roofs.
7/16” might even work for a rarely accessed storage attic, although it would be a little bouncy.
red94chev
Northeastern MD
Have the same think at my mom's garage but I only use it for light storage and don't get up there much. When I do, I try to walk on the rafters. With your situation, I think I would add something over it.
rburke65
Canfield, Ohio
You would probably realize a noticeable difference if you even glued and screwed 1/2 plywood over the existing floor.
P
paker
I went up there only to replace the air filter. It's going to happen twice a year.
May I interpret your post as "though bouncy, it will hold distributed load"? I will then leave it as is and avoid stepping in the middle. If I lose sleep because of this, I will add (glue and nail) 1/2" board as suggested by many.
Thank you.
b-boy
Buffalo NY
I'd double up the plywood.
I had the same situation in my living room. I tore up my carpet to install hardwood on my subfloor. The builder used rally crappy materials. I think some of the plywood may have even been 'used' when it was installed. They also used small scraps to patch the floors rather than using larger pieces. I found several 16" x 12" pieces of plywood on the floors in my bedroom. It barely spanned 1 set of joists. When you stepped in that area, you felt the board flexing.
The floors bounced and squeaked like crazy. I bought 3/4" plywood, glued and screwed it over the old flooring. I made sure to hit the joists with 3" deck screws, and made sure that my seams didn't line up with the old seams.
When I was done, that floor was incredibly solid, and no more squeaks.
Flargen
San Antonio, TX
I did 1/2" ply and learned that you want to orient the grain perpendicular to the studs... When parallel, there is absolutely noticeable flex, but no problems have resulted. The perpendicular pieces I laid later are way, way more solid.
Innovate1
I put 7/16 OSB in my attic with 24" spacing on the trusses and it's fine but I only use if for light storage and occasional access. Yes, it flexes a little but in my case the sheets are full 48" width. Less width will flex more - a lot more if it is a lot narrower. And as others have noted plywood and osb is stronger in one direction than the other. Sounds like you may have some narrow and/or short pieces or run in the weak direction. Also depends on how heavy you are but I am 190 lbs. Thickness and support spacing isn't all that affects flex. You can put another layer over if the flex bothers you but I would still recommend you pay attention to the other details to get the least flex.
NUTTSGT
Northern Central Ohio
Depending on the size of it, I think my biggest concern would be the area where the water heater sits. 40-50 gallon W/H that could be 350-400 lbs sitting in one spot. How does the floor look under it ? I wonder if it's sitting atop a truss bottom chord ?
