$5 oil change kit @AAP
Mr. Fixer Upper
Bergen County, NJ (North)
Who needs all that to change oil?
Well with no oil pan to catch the oil the procedure would look like this:
-Place 12 of the supplied paper rags under the engine compartment.
-Drain oil.
-Remove and replace oil filter while laying in a pile of rags soaked with 4.5 quarts of oil.
-Tighten oil drain plug.
-Wrestle with the pile of oil soaked rags.
-Dispose of in an environmentally sound fashion in a trash bag with your normal municipal waste.
-Use supplied funnel to put 4.5 quarts into the engine.
-Pour remaining half quart of oil over your head.
-Sprinkle supplied coco absorbent over entire body like you have been tarred and feathered.
-Eat supplied cherry GoJo gel
-Detail entire vehicle exterior with single Tub O' Towel.
Congratulations on your oil change! The 6 foot diameter oil stain on your driveway is a badge of honor. Next week we'll help you with your brakes!
bczygan
DETROIT! Arsenal of Scrappers
-Drain oil.
Have you been watching me change my oil?
That's my exact method!
Been there, done that, have the oil stained driveway to prove it!
Bill
kneeman
I must be an expert then. I just need the new oil, filter, drain pan and a few paper towels (plus tools)
kneeman
kneeman
Figure a way to keep the filter from making a mess and I'm set.
The drain plug doesn't make a mess usually but the filter does.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
chrisexv6
CT
Form a funnel and a regular catch pan works for me
Sent from my Nexus 6P using Tapatalk
kneeman
Yea I have one but it still isn't as clean as the fumoto thing for the drain plug.
Now I punch a hole in the bottom of the filter with a screwdriver, let it drain. Then unscrew it.
bfm336
St. Louis, MO
Wouldn't this potentially be a bad thing if you take a 4wd vehicle off road? A twig or branch hits that lever and you leak all of your oil?
leadfoot415
Livonia, MI
-Drain oil.
Now that is some funny ****!
