50 Amp circuit breaker , time delay ?
padronanniversary
Minesooooooota
Looking for some help on a question. I was reading the input requirements on a Miller252 and say that is wanted a 50Amp time delay fuse or time delay breaker.
I have never seen a time
delay or slow blow type breaker.
Can anyone recommend a 50 Amp breaker for 230 for an application like a ESAB 280 or Miller 252 ? Also is this something I can get at home depot or lowes ?:shocking:
I'm trying to get everything all wired up beforehand.
Thank you in advance !!
mrb
just get a normal breaker (the correct make and model for your panel) and you will be fine. All normal consumer breakers are time delay.
rodm1
I've read that a 60amp is an exceptionable substitute. Any 50amp will work fine.
Flange
Northern England
All circuit breakers are rated for the time it takes to break the circuit. An electrical engineer will design a circuit for a particular application and specify what spec breaker to use.
Most common circuits, say for a domestic situation, will be covered by standard breaker for that situation. For anything else then ask someone who knows.
P
padronanniversary
Minesooooooota
typically fuses have blow curve characteristics. I would assume a breaker has similar; both of which are based on current and time, not just time.
