50a Welding Outlet - Vote Which Wire
Which Wire?
  • #8 THHN
    Votes: 6 27.3%
  • #10 THHN
    Votes: 1 4.5%
  • #6 THHN
    Votes: 11 50.0%
  • Old #6 Wire that still looks in good condition - Stripped from 6/3 WG NM (Not NM-B!) Rated at 60c
    Votes: 4 18.2%
  • Total voters
    22
HamAndEggs
Houston, TX
Details here:
I'm looking for your vote if I should use some old copper 6/3 Wire. Its NM wire, not NM-B Wire. I will strip the jacket and run in conduit. Its rated at 60c
Install will not be inspected
Per the NEC, the lowest wire gauge I could go with this welder would be #14 because of the duty cycle. But that's obviously the cheapest way
Terry D
St. Louis, MO.
Is this circuit just going to be for that welder, or do you want to plug a EV charger in there also. That will tell you what size wire. I would not use the old wire.
KenC
oklahoma
Just so you know, inspection or not, stripping cables and using the individual conductors is not code compliant. For a lot of reasons, I'd go with 10ga THWN. Or be sure the THHN is dual rated as W also.
gtae07
Fayetteville, GA
Wire it as a general purpose 50A outlet using #6 NM-b or #8 THHN in conduit.
+1
Build in the extra capability. You never know when you might want to plug something else in there. I wound up using my "welder" outlet to run an old electric range so I could bake parts. And the ine in the attached garage will probably wind up with an EV charger one of these days.
TractorJeff
Elkhorn, WI
6ga. Only because you NEVER KNOW what will get plugged in there later!
Or a BIGGER Welder!
I Know because I started out with a 20% Duty Cycle on high range full output and ended up with a 60% on high range full output but 100% in the ranges you would typically use.
Noltz
Ontario, Canada
#6 THHN can carry 60A and is spec'd for most EV's biggest chargers. Currently wearing a Nema 14-50 plug, but likely will put it into a sub-panel now.
