50B Nugget set from the beginning
don long
southern california
I've had this Nugget tool box for some time and have decided that the time has come to get it cleaned up and loaded with the Nugget set that came with these boxes.
So lets get the ball rolling.
First on the agenda was to build the tray that was missing. I pulled out a sheet of 18 gauge metal and sheered off a piece that was 19" x 48"
Then took 8" off that for the bottom of the tray 8" x 17" Next cut was for the side panels 17' + the flanges so I cut 19" off the strip. Then sheered 2, 2 1/2" from that for the 2 sides. Marked the length of each strip by 1/2" for the bottom of the tray then cut a piece 1" x 1/2" off each end and went over to the break and bent the 1/2"x 17" 90 degrees leaving the 1" on each end of the strip for the mounting flanges for the end pieces. with the ends bent I welded both sides to the bottom plate. Taking what was left from the original 8" x 48" strip I cut the 2, 8" end pieces 2 1/2" high bending 1/2" for the bottom and welding them to the sides and bottom the tray was made. It needed a divider for the sockets so that was an easy piece to make and weld in before sending the tray to the booth for primer
I had to bend an 1/8" piece of stock for a handle fot the tray but want to get primer on before welding the handle onto the tray
So with the tray made I focused on the toolbox. It needed to be sand blasted to get the old paint off so into the blast box we went.
The box came out pretty clean
Out of the blast cabinet I took my 3" grinder with 80 grit paper and went over the entire box looking for imperfections to fix. All I found was a couple small dings and several spot wald marks so a little time with some bondo and some sand paper the box is now ready for a coat of primer
Before putting the tool box into the blast cabinet I took the 2 door moldings off the box. They are made of brass so a few minutes with the buffer and my moldings are all shined up
Tomorrow the box will get primed
D
don long
southern california
I have one in much worse condition, someone painted it industrial green. Nice work as always Don.
Looking forward to following this one Don, and seeing all those shiny chrome Nuggets in it!Thanks Dreamer
Thanks Dreamer
Get on yours. they are a nice small box
Looking forward to following this one Don, and seeing all those shiny chrome Nuggets in it!:)
Thanks Farmer
I'm going to have to hunt down a couple more pieces
D
don long
southern california
Well I found a little time this morning to work on my tool box.
I found a lock and put on the badge from Ysguy (thank you) Then turned my attention to the pad that came with the box.
A Little lacquer thinner and a light wire brush and it cleaned up pretty well. good enough to put back into the box.
Now it's time to clean up the tools and put them into the box
D
don long
southern california
drooling again. Don, your stuff is totally awesome
Thank you Cobbler
We can close the book on this project (almost)
After gathering up all the tools I had for this box I'm short 2 pieces. The 10" extension #39990 and the handle bar #39986.
I spent the day polishing these tools. Some were in pretty poor condition BUT with the help of a soft bristle brass wheel my ultra sonic cleaner my buffing wheel and some lacquer thinner the set is ready for display in the Big Party Garage
Farmer J.
UK, Cornwall/Hertfordshire.
Oooh, that's all looking rather nice and shiny now Don. I was wondering what condition the tools would be in and if you would have to get any of them re chromed but they have polished up lovely. That's going to look good on display in your Garage. (y)
930dreamer
Amarillo,TX and Stinnett,TX
I painted the red rings on the torpedo handles and picked up the torpedo speed wrench that OUTOFBOUNDS had offered so this box will be close to complete. Just short the handle bar.
Still looking for the shorter torpedo hinged offset to swap out of the box. If you have one to sell let me know please.
Picture of needed tool!
