5426 Proto breaker bar
talking
East Texas
I have an old 5426 proto breaker bar that is loose like hell . How do i get the pin out . I notice someone that own it before me tried but failed because one side of the head is not damage and the other side is as if someone beat on it with a nail and hammer . I did a search on here and saw the post of removing the sk breaker pin . Is the old proto breaker pin removal the same? I do own 3 other breaker bars, so it not as if i need to fix it right away just something to do while I am bored
Grogan14
I'm assuming they're pressed in. I was kind of wondering the same on this Matco C24FM that I got at a yardsale over the summer:
For, yes - 10 cents!
Unfortunately:
I don't have that particular Breaker, but every flex head breaker I've seen is pressed. If the head is loose inside the pressed parts, you may want to make up a shim to keep from bending the forked part of the bar before pressing.
