OK here is a question for the electric motor guru's out there. I bought a first Bridgeport clone mill last weekend and I'm trying to get it all set up now. I knew it had a 3 phase 575v motor on it when i got it but i figured I'd just swap it for a single phase one. Upon closer inspection, the shaft of the motor is pretty unique. It's a 2J2 head. So my question is, can the motor be rewired to a lower 3 phase voltage, ie 220v 3 phase so i can just run it with a vfd? The motor plate only says 575v. But there are 5 wires coming out of the motor into the connection box. Two wires are just capped off separately. Or will that be impossible/not cost effective? My other option is the cut the shaft off of the three phase motor and through some careful machining on the lathe, graft it onto a regular single phase motor. I've looked all over the place but can't really find and answer.
Thanks in advance
Mike Simpson
Thanks in advance
Mike Simpson
