5hp 240 Volt Air compressor Install
alfredeneuman
Fullerton, CA
If the capacitor is the problem, also check the centrifugal start switch.
You should hear an audible click within a couple of seconds.
Otherwise it is stuck. (and possibly why the capacitor failed in the first place)
Bert_
NW Iowa
Ignore the metal capacitor for now. It is not the cause of a no-start condition. The plastic capacitor is the start capacitor. It doesn't look bad but looks don't mean that much.
What kind of meter do you have? You may be able to perform some tests.
If you do change it remove only one wire at a time and connect it to the new capacitor.
A
AllThingsOld
My house
This is the only one I have
Bert_
NW Iowa
Disconnect the wires from one terminal of the plastic capacitor. Set your meter to ohms probably the 20k ohm scale. Short the capacitor with a screwdriver then connect your meter. The reading should start low near zero and then rise towards infinity.
This is not a really accurate test but it will usually tell you good/bad.
All this is with the power to the motor turned off.
pattenp
Virginia - USA
Does the meter have a capacitance setting? This symbol -|(-
Edit:I couldn't tell on my phone but now see the meter doesn't have a capacitance setting.
A
AllThingsOld
My house
The capacitor tests good.. 0.L
Terry D
St. Louis, MO.
You said in post # 63 that when you powered the motor up, it hummed, and when you pressed the reset button , it then tripped the breaker. If the motor is shorted to ground, it would trip the breaker instantly. Why is it tripping when you press the overload button, that just sounds weird. And you for sure have 240 volts across the 2 line terminals of the motor, not 120 volts And the motor is not locked up? It would be nice to check the caps with a actual capacitor tester. Is there anyway to take the belts off, hand spin the motor in the right direction, and then apply power to it and see if it starts. Make sure your hand is clear, before you apply power.
A
AllThingsOld
My house
You said in post # 63 that when you powered the motor up, it hummed, and when you pressed the reset button , it then tripped the breaker. If the motor is shorted to ground, it would trip the breaker instantly. Why is it tripping when you press the overload button, that just sounds weird. And you for sure have 240 volts across the 2 terminals of the motor. And the motor is not locked up? It would be nice to check the caps with a actual capacitor tester. Is there anyway to take the belts off, hand spin the motor in the right direction, and then apply power to it and see if it starts.
I took the belt off, the pump turns, no issue there. The motor on the other hand, does not budge. Unbelievable... Is there any option other than getting a new motor ?
Terry D
St. Louis, MO.
There is your problem, the motor is locked up. If it is just bearings, they can be replaced. If you have a shop do it, it might just be better to get a new motor depending on the cost. Its not hard to change bearings depending on your skills. Assuming that it is just bearings. I defiantly would be giving the person you bought it from a phone call
A
AllThingsOld
My house
I did call him, not sure what good it will do, after all he is the guy who told me it ran great, no issues etc.
Terry D
St. Louis, MO.
Any idea where I can find replacement bearings ?
There should be a number on the bearing. They should be available online or if you town has a Grainger. Once you pull the end caps of the motor off, you be able to determine what the problem is, and if it is repairable. There are videos on Youtube on this. At this point, you really cant do it any more harm. It could save you the cost of a new motor.
Norcal
Another source for bearings is if supplier such as Kaman or other is nearby, but online will probably have better prices, I would avoid ChiCom bearings though.
sberry
Brethren, Michigan
Auto parts stores, tsc has some, I got one there a while back for a motor.
Finding it is ok, know the problem, it's a good fix, new bearings add reliability. It's the price of used.
Nothing wrong with a fresh cap especially at the right price. I have 3 or 4 things that take the same, I stock one.
A
AllThingsOld
My house
Here is what I discovered..
A
AllThingsOld
My house
the RPM of the original motor was 3425, should I buy an identical replacement or one that runs around 1725 ? I am so pissed at myself
A
AllThingsOld
My house
Is this a good motor
Bert_
NW Iowa
Baldor makes good motors. Also has a 1.15 service factor which is better than the original.
A
AllThingsOld
My house
Thank you guys for taking the time to walk me through this nightmare, I really appreciate everyone’s input
A
AllThingsOld
My house
Shaft diameter on the one in the link is 5/8, shaft diameter on current motor is 7/8... Would that be something I could get an adapter for ?
