5v reference signal generator
MrNatural
I know that one is incorporated into The Hook: generates signal voltage between 0-5v dc in .5 volt increments. I am also aware that Blue Point provides a stand alone version. Both are pretty expensive options. Is there anything more affordable out there?
Professional Tool User
BC
There are 5 volt adapters that you can plug onto other power probe products. Otherwise, there's the DIY route if you are any good at soldering. I don't see how 4 AAA batteries hooked up in series, a potentiometer with a knob that cannot be turned up to more than 5 volts, and a probe can't be soldered into a improvised solution.
Citation
Indy
What type of signal? Do you just need a voltage or does it need to be pwm or something?
If cheap is all you need get a 9v battery and an adjustable voltage converter. You just need a screwdriver and multimeter to adjust the voltage.
Beyond that, really basic signal generators can be had for $20-30.
MrNatural
I like the thinking and a diy rheostat/battery solution would provide more sensitivity than the commercial.5v incremental step option.
Need to test this sensor by substituting two precise dc ( non pwm ) Voltage’s.
Will leave the 5v supply and return connected to the ecu and cut the return to which I will attach the diy voltage generator. Ecu expects to see .5v pre crank then between 2.2-3v depending on rpm’s. At 3.2 v the ecu closes a pressure regulator and the engine will not start. I have checked the cranking voltage and it is immediately at 3.2v so that indicates a no start due to FPS failure, but the replacement part is hard to source and expensive, hence wanting to bypass for conformation purposes.
http://www.f5r.co.uk/home/czujnik-cisnienia
MrNatural
I am now thinking in regard to this particular sensor. As the ECU expect to see between 2.2 and 3v dc in order to pulse the injectors,but not more than 3.2 V in which case it shuts off the fuel supply: could I not just wire 2 AAA rechargeable batteries in series giving 2.5v? Is there a problem with that logic just for testing this particular sensor?
Mr_B
Reading
batteries is an option but could have variables on how well works in practice .
If you already have the 5V reference on vehicle you just tap that and use potentiometer trim voltage value and feed that to your test procedure .
A 12v to 5v regulator is few bucks off eBay, add in a potentiometer or source regulator with onboard adjustment and you got a very useful sensor 0 to 5V voltage test tool for like 5 bucks .
I been using these solutions and resistors for diagnosis for years and it works great and is available and cost effective for everyone ...
RPH
Michigan Thumb
Got this for loop testing. It supplies 0-10 vdc by 0.1 increments. Also provides 0-22 mA loop.
Runs from usb or battery pack. $27 delivered.
Uctronics.com
MrNatural
Thank you all once again for your valuable experience. I just really appreciate the wisdom gained through experience and then most generously passed on to others.
It would be nice to try the simple elegance of a simple pragmatic approach. I really like, and may yet try for fun the very affordable self-constructed tester in a box solution, but the Utronics at 27 dollars seems to tick all the boxes for testing by substituting a proven signal voltage, for many sensors on a 5v reference circuit.
It’s accurate, very adjustable, and takes a rechargeable battery. If it also has the facility to lock voltage generated at a preset maximum level for safety (4.5 v dc ) which I think it can do reading the Amazon comments, then it looks pretty damn perfect for the task.
Thanks again to everyone for sharing your valuable knowledge. ��
