Too late now but just asking the question, I recently ran a new wire in the wall for a welder outlet for my miller 210, 50amp receptacle using 6-2 nmb.
After patching up the sheetrock and finishing the wall, I trimmed out the outlet and realized the hots are 6g but the ground is still 10g. This is the only jacketed 6-2 they had for sale, so I didn't think much about it and did not notice the ground before installation, but I'm just making sure this is typical and will be ok running a m210 at full bore on it.
The drop from breaker to outlet only has around 4-5ft of 6-2 coming down from the panel and over one bay so it's a short run.
I also ordered a 50ft extension extension cord from a welding supply to use with this outlet. But then noticed it's 8-3 not 6-3 wire. Is this fine for the max power from a m210 at 50ft? The supply sells it as a 50a cord and has 50a plugs on it.
Thanks for any confirmation that this is all good. I assume I should be ok, as I've read others using 10g or 8g with 30a and 40a breakers with their 210s without issue. Maybe they never use full power or extended runtimes, but these welders have been around for a while and seem to operate ok in a variety of power inputs.
