DTL504
I have 50FT of gray 6/3 UF from the detached garage subpanel going approx 18" underground into 1 1/2" conduit to the back of my house which is brick with crawl space. The easiest way to the main panel is to bring the cable into the attic and feed it down into the wall into the main panel. My 6/3 UF ends about 6ft above ground. I am adding a 4x4x4 junction box for a splice to transition to the appropiated wire and continue the run up the back wall to the top gable into the attic using a 1/ 1/2" LB then to the main panel crossing the beams and through the bedroom interior wall where the main panel is located. What option/s do I have to continue the run from the the outside wall to the main panel inside the house
