6-50-R wiring
Born_Annoyed
Hurricane Central
I have Piped and mounted a 6-50-R receptacle located right under the service panel.
Question on the wiring:
Black from breaker to hot.
Red from breaker to other hot.
Green to the GROUND Bar.
All wire is 10g AWG.
Is this the correct way??
I should also mention this is a sub pannel. The main disconect is located outside next to the meter.
sberry
Brethren, Michigan
Breakers 20 to 50 are legal with this machine with that wire. A larger breaker would support a buzzbox type welder if needed but a 30 is tailor made for the 180.
