Tim Fitzgerald
Just got off the phone with rheem and they say that I need 60 amp double pole breaker..., what is the difference?? Does it mean that the breaker takes up two slots in my panel and Im assuming it still only has two hot legs entering it..., Im confused. I knew that a routine 60A breaker would have exceeded the 80% capacity rule as this heater operates at 55 amps when heating. Could someone pls explain the difference
Im new to this and like to have a full understanding prior to even coming close to wiring it...
could also someone pls breakdown the "can you see the heater from your main panel question in reference to if I need a disconnect box between the service panel.
Does visible mean unobstructed??? Reason is because it all inside my shop, there will just be 30 foot wall (bathroom area) where it will be located between it and the breaker box
Thanks in advance
Thanks in advance
