60 degree start on flourscent?
AllenB
Columbus, Ohio
I've noticed that the cold start lights are much more expensive than the ones that say they start at 60 degrees. What happens if I operate them in say 20 degree weather. Will they start at all or will they dim or flicker? I can warm the garage up but may take a bit. Thoughts??
HaroRider
New York
I have regular florecent ge (I believe) bulbs in my garage and they start fine WELL under 60*. Might flicker a bit at startup at around 30*F but otherwise they are ok.
ForceFed70
BC, Canada
We need to know what package.
I've found that my T8's with electronic balast seem to start almost instantly in temperatures below freezing, but do take a minute or 2 to reach full brightness when it's that cold out.
Falcon67
Merkel, TX
But what about the power consumption, if I want to think in an economical way????
T8s use 1/3 less power than a comparable T12. That's not some off the cuff internet stat, that's personally measured amp draw after a change out from mag ballast T12 lighting to electronic ballast T8 lighting of the same style and quantity.
Gary S
Bismarck, ND
The T8 fixtures with electronic ballasts I see on the shelf today are rated at 0 degree startup, and they are cheap.
If you need more than that, you need to use the more expensive HO lights rated at -20 degrees.
HaroRider
New York
Damn, if your working in a shop that is -32* or even 0* that is crazy. Shouldnt need those kinds of bulbs.
Falcon67
Merkel, TX
I suppose that depends on the shop
images
Gary S
Bismarck, ND
My shop drops to around +15 degrees if left unheated when outside temp drops to -40. I want my lights to light at that +15 when I walk in there in the morning and start my heaters. The cheap Menards 4' T8s do that, and cost only $12-15 per fixture.
This thread got me thinking. I don't believe I could even find a 60 degree shop light in this part of the country. All of them sold here today are good to 0 degrees.
