Ok a company has contacted me about building a sign for them. Sign building is what I do, but this one brings about ALOT of questions and concerns. They want a steel sign 60' wide x about 8' tall. Normally that wouldn't be a problem IF it were to be mounted in a different manner, such as against a building or some other good support. This sign will be mounted on top of 14' tall posts one on each end, no support in the middle. The bottom of the sign will be flat, the top will have an arch to it. Ive built signs where the ends attach to the top of posts lots of times but usually only around 25' or so wide, or shorter. 60' is a huge span. I would use rectangular tube top and bottom for the horizontal piece and the arch so Id have to roll some tube for the arch but would have to outsource the rolling because my roller isn't big enough to handle the size of tubing Id use. Im not even sure yet what size of tubing would be necessary for a span like that. I would weld vertical pieces of tube from the bottom horizontal tube to the top arched tube making a solid frame, then would cut the sheet metal in 20' sheets on the plaz table and bolt the skin to the frame. Id weld brackets to the frame so the sheet metal would bolt/rivet to it. All I know is that frame will have to be strong to hold up well when winds hit that large surface area because there will be no cutouts from the sheet metal for wind relief.
I know I can get tubing in 40' pieces no problem but 60'? I could weld the tubing together to make it 60' long but do they make tubing in 60' lengths? Then I was thinking about shipping and as far as I know semi trailers are 48' long, do they come any longer? If not I suppose it wouldn't be a problem to double up with a shorter trailer and pull doubles and have that second trailer as a buffer so the sign doesn't overhang off the trailer 12'. I could set it up a couple feet so it wouldn't have any contact with the rear trailer.
Then there is the painting / powder coating part to think about. I would paint the frame and powder coat the rest of it is what I was thinking since the rest would be broken down into small enough sections to fit inside a 20' powder coat booth.
