60gal Mount questions
02chuck
Collegeville, Ca
Good Morning Gang
I have a 60gal upright compressor coming. I would like to isolate it from the shop slab to minimize sound transfer.
I was looking a some floor mount vibration isolators at Grainger verses just the basic vibration pads. How would I select the
pads ( i.e. weight ratings) Compressor weighs 300lbs
Thanks
GeoBruin
You might be overthinking it. 300 lbs divided by 3 or four feet isn't a lot of weight per foot. It seems like any kind of dampener material intended for the purpose would be fine. I have these because they were cheap and available at home depot down the street.
Husky Heavy-Duty Vibration Pad for Air Compressors
SKU# 305308562
Hockey pucks have also been popular in the past.
Lucid Moments
Gainesville, Ga
I did the Husky ones on mine, but with that good old 20/20 hindsight what I wish I had done was just leave the thing on the pallet it came on. It would give me a little more room under it for drain plumbing and help with vibration isolation at the same time.
kelpaso1
MEMBER EMERITUS
New Brunswick
Pallet does nothing for isolating vibration, in fact it makes it vibrate MORE Rubber or hockey pucks on the feet are the best isolator and set on the concrete floor.
sparky 1971
Central Iowa
I didn't want to drill into my floor, so I just lag screwed mine to two 2X2X3/4 sheets of treated plywood stacked on top of each other that sit on the floor. That was three years ago though, with the price of plywood now, the vibration pads wouldn't be such a bad idea.
MileHighRover
There's a reason why nearly every (maybe every) compressor sold that comes on a pallet will have a tag on the compressor stating the warranty is void if the compressor is not removed from pallet prior to running.
IMCA38
Bennet, NE
I just cut up pieces of rubber belting. Drilled into the concrete and used wedge anchor bolts, but just tightened the nuts to sung on the compressor feet.
kelpaso1
MEMBER EMERITUS
New Brunswick
Why bolt it to the floor? Its not going anywhere if you put pucks/rubber under the feet and stick it in the corner. What good does bolting it to the floor achieve?
ZRX61
Solar Blight Valley, SoCal
Ask someone who lives with quakes... They're top heavy, they will make quite a dent in you, your car or child when they tip over. My 60gal is bolted down with wedge anchors. Same reason water heaters are required to be strapped to the structure here.
ZRX61
Good Morning Gang
Thanks
Mine had 3in washers that were rubber on one side between the feet & the floor at my old place, now it lives in a carpeted garage so just that, no rubberized washers.
Honch
Danville, IN
My 30 year old 60gal Craftsman has suspension bump stops bolted to the feet.
Be careful if its a compressor under warranty, many are voided if its not bolted down. Using isolators or keeping it on skids apparently doesn't support the tank properly.
Citation
Indy
Like others said, I would do it for safety. Even if it isn't bolted down, if we are dealing with a vertical tank I would do something to keep it from tipping over.
02chuck
Collegeville, Ca
Hi Guys
Thanks for all the ideas on how to isolate the compressor from the floor. I went with the horse stall
mat and added 4x4 squares cut from the mat for each foot. Since I live the state known to rock and roll at times (California).
I used 3/8 anchors on two feet as a safety option. Earthquake safety is just part of life here.
Thanks again for the input.
C
Sumboodie
AK
Hi Guys
C
Mine didn't tip with a 7.2 earthquake a few years ago. I think we have 2 or 3x the earthquakes per year than Cali does.
