60gal upright air compressor floor attach?
wazzabie
I'm not able to drill into the concrete floor in the garage. Can I run this air compressor not attached to the floor?
johnre
Portland, OR
It's not just about keeping it from tipping; you need to keep it from skating across the floor. And getting the right kind of pads will also isolate the vibration.
If you can't hammer drill the floor, why not use a heavy duty construction adhesive to glue down a couple of 4 x 6 boards, and bolt it down to that?
sparky 1971
Central Iowa
I stacked two pieces of 3/4" treated plywood and lagged screwed the compressor to those. Gravity does a pretty good job of keeping everything in place.
liliysdad
Mines been sitting directly on the concrete without being attached for four or five years now. It hasn’t moved a bit.
It’ll be fine.
Davefr
OR
Just get some rubber anti vibration pads. They'll reduce the noise, cushion the compressor and prevent any movement. They're cheap and the right tool for the job.
Nessism
Torrance, CA
A wood platform sounds like a good idea, along with some rubber isolation pads. I bought some pads off eBay, made from old tires. Very tough and durable.
N_Jay
Bolted to 2X4 pieces to lift a bit to get to the drain.
The bolts go through teh 2x4 and into hocky pucks.
Hels with vibration and wanting to walk.
mikedodge
Like so many others mine is also on its original pallet. Plus if you ever have to move it it makes it easier.
BonzoHansen
I put four hockey pucks on both of my 80 gallon compressors, one in the shop and one in the garage.
They haven’t had any significant movement in fifteen years.
Similar here. Mine is sitting on some leaf spring bushings because i had them and they were perfect size. It hasn't moved. I did add some cables in case it decided to walk, but it never has in at least 15 years.
oscarsnapkin
Every larger compressor I’ve ever had or installed for others has been left bolted to its shipping pallet with a chunk of old rubber inner tube under all four corners. Never had an issue with one wandering around or having excessive vibration.
We had a gigantic IR compressor mounted to its shipping pallet for 15+ years. No movement whatsoever. Plus, it made it easy to move when we sold the building. I definitely wouldn’t place it solely on the floor. Metal feet on concrete seems like trouble.
rocksnstumps
My 60 gal upright has a couple of wires up high going to a couple spikes about 5 ft apart to ensure it doesn't tip. Never did bother to bolt it to the floor in the last 27 yrs. It's use in my polebarn is infrequent in my case however.
aka Larry
Eastern, NC
I also have a 60 gallon upright compressor. I bought rubber isolation pads from MMC that I bolted onto the feet, and mine hasn't moved in 10 years. I never even considered bolting it to the floor.
whateg01
doo dah, kansas, usa
How much does your floor rock that you afraid of it tipping?
SouthernIllinois
Cheap-O rubber tiles Menard's had on sale.
Bought a box for $10, used four of them and gave the rest away.
80 gallon commercial compressor hasn't moved an RCH
leadfoot415
Livonia, MI
I have a 5hp 2 stage IR 60 gallon upright inside a wood framed, osb sided "hut"...sitting on a couple school bus mudflaps and connected to the wall with a flexible hydraulic hose to bridge the gap to the black iron pipe I plumbed the rest of the garage with. Cement floor garage.
T444e
I have my 5hp 80 gal bolted to (2) pieces of 4x4 HSS set on (4) vibration pads. I needed height for the condensate trap. No issues with it vibrating off the pads. My compressor is piped into a copper distribution system with a braided SS flex.
MichaelP
IL/WI border
My 60 gal Quincy rests directly on concrete. No rubber pads or attachment. Flexible hose connection. No movement or other problems for about 15 years.
rocksnstumps
Maybe not so much tipping but just moving around slowly from the vibration. But figured securing it up high it's NOT gonna tip either. Not tied into any hard piping on the wall or anything, just a cord reel
Note: My vertical 60 gal tank only has 3 feet while others on here talk about using 4 rubber pads so can assume their compressor has 4 feet and a bit wider more stable stance.
JuncleJohn
Omaha, Nebraska
No bolts holding mine. My 60 gallon upright is just sitting on some thick rubber pads. It’s been that way for at least 15 years without an issue.
John
