Scimonetti
1947 Shopsmith 10e restoration
I recently picked up this shopsmith 10e (e for expirimental) along with a 15 inch planer for 50 bucks! I'm fixing this up completely to put in my dad's garage
It was not made by Shopsmith but by the Magna Engineering corp. Both of the machines came with good motors but were all beat up.
Here is the main frame as I got it. The handle for the DP was replaced with a wooden one at some point, shouldn't be hard to fabricate though.
It came with a whole box full of accessories and a manual.
The coolest piece in my opinion is the "speed changer" It mounts between the motor and headstock and acts as a variable diameter pulley like a Vari slow on a drill press.
It runs so many accessories for different applications that it needs to change speeds easily and without losing torque.
Here are some accessories.
I spy a few lathe faceplates, one welded badly, a lathe drive center, lathe tool rest arm with broken rest, tailstock, mortising attachments and hold downs, miter gauge and table extensions and a few pieces to hold the bars spread evenly and mount it to the table.
In this picture added are the table for DP, saw, horizontal mortiser, sander, drill chuck, drum sander, moulding head and loads of cutters. Even one in the box still!
It has a 3/4 Hp Dayton motor.
This is just a preliminary run through of how I got it, I have 3 restorations going on right now, the planer being a huge one so progress will be slow. Hope you enjoy!
It was not made by Shopsmith but by the Magna Engineering corp. Both of the machines came with good motors but were all beat up.Here is the main frame as I got it. The handle for the DP was replaced with a wooden one at some point, shouldn't be hard to fabricate though.
In this picture added are the table for DP, saw, horizontal mortiser, sander, drill chuck, drum sander, moulding head and loads of cutters. Even one in the box still!It has a 3/4 Hp Dayton motor.
I am unfamiliar with the 'e' series. In any case, looks like you've got yourself a serious project there. One thing I don't see are the legs. Did it come without them?
A half hour straight of scrubbing later. I used green scotchbrite with liberal amounts of WD 40 to help it cut. Use plenty, trust me scotchbrite needs it to work. I suppose water might work but I've never used it.
