Hobby_Man22
I went to the shop today turned on the heat pump and it went from 48 to 69 in about 5hrs I think. Then the temp dropped to 33 and it when down to 66 degrees and stayed there. I have a good man 5 ton unit 60,000 btu. I just about have all the insulation up on the roof. Most is up on the walls, how critical is insulation on the walls? I'm about to call the installer and tell him the unit doesn't keep up. In mean it heats, but it showing run the entire 9hrs I'm at the shop. It was in auxiliary heat mode too, so it was pulling 55 amps that whole time. It does have a 15k heat strip in it too. I wonder if it needs to be upgraded to 20. Then again ibwobder if I'll have the same issue in the summer where it doesnt cool. It's sized right for a 30x50x12 building. 5 ton heat pump 61,000 btu.
