mod600
So I'm hoping to start sheeting the interior walls of my shop with 1/2" OSB soon. It's a 32x64 pole barn building, I have a divider wall, so I have a 32x32 shop and the other side is cold storage. My divider wall is a 2x6 stud wall and I have that wall all ready sheeted. The other three walls in the shop side, I plan to run the OSB horizontally. I have 2x4 blocking/purlins to support/back all four sides of the OSB. I planned to use 8d galvanized nails. These worked just fine on the divider wall. Except I noticed where I had some horizontal blocking that I added for future shelf supports, the 8d nails would break thru the 2x4 backer. So I'm wondering where I have the 2x4 blocking, would it be better to use 6d nails to keep from punching thru the 2x4 backer, or am I better off sticking to the 8d and not worrying about them going thru. No one is going to see it, just curious on holding power...obviously if going to 6d, I should run the spacing closer to make up for the smaller nails. Thought I'd see what you guys thought.
Thanks!
mod600
Thanks!
mod600
