Do most of you own 6pt and 12pt sockets? If so, what situation dictates which one you use? I always assumed 6pt was the way to go unless the head on the bolt is a little off and could easily strip. Then you would go with 12pt?
Threads galore on this one, do a search, but you would normally use 6pt for 6pt bolts and 12pt for 12 pt bolts, or 12 pt if you need that extra angle.
One question for those that only use a 6 point socket on hex bolts and nuts, do you have all 6 point wrenches for hex bolts?
Enough said......
Enough said......
Watch this video and it will all be explaned to you
Enough said......
No, but I use the open end to break the bolt loose![]()
