7 Gang over workbench?
LXCam
What’s your question? I can’t say in the 40yrs of doing this trade I’ve ever seen a 7 gang box let alone a P-ring for one. But then again that doesn’t mean much. I’d be more concerned with getting a trim plate that matches whatever devices you plan on installing before I’d rough one of these in.
Skooterj
Indiana
Not really a question, just thought it was interesting. If its attached to both studs, it should be rock solid. I saw boxes up to 10 gang. But they are too wide for 16" studs. Platt has faceplates too.
Shiftless
East Bay SFO
I can’t envision an application where a guy would need 7 devices all in one box.
If somebody had that many switches for an elaborate lighting installation, just install 2 four gang boxes.
To provide plenty of receptacles over a work bench, it seems to me that having them more spread out makes them easier to use. My main work bench is just 7 feet wide and I wired it up with a 4x4 box with a single duplex receptacle on every other wall stud. I have the future option of installing 2 duplexes in each box if necessary but in the years it’s been in use, I’ve never come close to needing that.
yatg
Southern Oregon
u2slow
BC
I don't care much for gangs beyond doubles. Rather connect multiple doubles with ******* or short conduit.
dscheidt
Gangable switch boxes can be made up to any desired size, and are pretty common for lighting control in commerical installations.
10 switch cover plates are stocked in decent supply houses, bigger ones are available. Using two boxes for switches where you could use one is pretty hacky.
Duke74
Pierceland
Even 5 gang boxes aren’t that common. I have never seen a 7 gang box either. I would go with a 3 and a 4 on both
Sides of a common stud.
u2slow
BC
dcg9381
Austin, TX
Can you get a cover for 7-gang? I get needing stuff in a location, but I'd rather have this split into 3-4 gang boxes...
egdede
I never would have guessed:
Shovelhead
DEEP EAST TEXAS
Dang right. I absolutely agree.
