thatrevguy
Hello, I happened upon a horizontal 80 gallon air compressor that needs some love for $400.
Pump looks like a Saylor Beall 707 clone. Body shop I bought it from said they bought the pump originally from NAPA 7 years ago.
Pretty obvious the pump fell on it's face at some point. Unloader valve on centrifugal unloader was missing and unloader pin slightly bent.
It came with a 10hp 3phase; swapping it for single phase 7.5hp for residential use.
Got the pump completely disassembled. Bit of rust in valve assembly and lots of sludge. Bet they never changed the oil. Soaked everything in vinegar and simple green except rotating assembly. Cleaned up well by hand.
Got a tune up kit for the pump. Everything looks right except valve springs. The pump originally had 8 identical springs. Only 2 HP intake had different springs of lower stiffness... The TUK came with 12 springs total of two types. A set of 6 stiff springs and a set of 6 lower stiffness springs. Not sure how new springs should be assembled. Should I buy a different batch of springs? If I combine 2 lower stiffness springs together their combined resistance feels very close to a single stiffer spring. Having to combine springs seems odd.
