73 yr old garage floor help please
KiWinUS
Charlotte NC
Default 73 yr old garage floor help
G'Day guy's , I need advive on my 73 year old garage floor. I have a "Rock" garage that was built in 1945 that I am turning into an "Art Studio" for my Daughter, has several issues I need advise on.
The concrete floor is in bad shape it is very rough , has cracks , some quite large , some area's kind of powdery. I don't believe there is any moister barrier under it as if you sit certain thing on it (like a 5 gal can of thinner or something plastic) it draws moisture from floor.
What can I coat of put on this or ? Replacing is not an option at this time.
Also bottom of framework that sits on concrete is mostly all rotten , moisture or termites dont know what. What should I put between new timber & concrete?
Treated timber or not?
Thanks for any & all help!!!
Thanks
Cheers
Tony
TractorJeff
Elkhorn, WI
Yes on the treated! This old house just did some episodes on a couple of houses in Charleston, apparently termites are a common problem.
rjn2649
Il, A little west of Chicago
I'm doing about the same thing, cant change the floor, and just changed 1 of the sill plates, garage built in 1944, nothing but powder when I was trying to cut out the sill plate, replaced it w/ 4x4 treated, fortunately my studs was pretty solid about an inch up from the sill. The T&G siding , not so much.
This area floods and about 2-3 times in the summer the sill plates are underwater for a few hours. I didn't put anything between the new sill and the cement, probably should have, but heck its lasted this long, it will probably outlast me now...
James-W
Southeastern Wisconsin
Pictures would be nice.
I would rip out the old floor and go with treated wood for a new floor. But I would also do some landscaping so that you can avoid the flooding. Flooding is not a good thing and if the problem can be fixed then you will be much better off.
Armorpoxy
The have a 93 or so durometer. Much harder than a gym tile, but more give than a p,attic tile. Best to email directly at below for a free sample piece.
