75 amps is very low for "normal" stick work. You'd probably be running at max amps, which equals max duty cycle.
I'm not just jumping on the buy big bandwagon, but this little machine will surely be an exercise in frustration and ultimately lead to purchasing a larger machine.
Almost anything you can do with a small stick at 75 amps, you can probably do with your MIG.
tech correction:
Running a machine at max output means you get the MINIMUM duty cycle out of the machine.
I agree that a 120 V SMAW machine with a 75 amp max output will be rather limiting in what you can do with it.
Most likely it will limit you to running a max of 3/32" electrodes (not a big problem there, it is still a 'standard' size and relatively available in different electrode brands and types), but you will still be running the machine at its max output (or darn close) and will have a short duty cycle (with a 'small' diameter rod to boot). Weld a bit, wait several minutes, weld a bit, wait several minutes, etc.
Your call on whether the machine's power (amperage) and duty cycle and rod size usability limitations override the portability factor.
Step up a bit with your budget and there are some 120/240 V inverter stick welders available. Gives you the portability of a small inverter stick machine, and the power option of running on 240 V when you want/need more power yet still have the option to do some welding with 120 V power (at a reduced welding amperage, using smaller diameter rods, etc)
