'78 F350 Dually Project
R
RivennHewn
PNW
Thanks Bears,
Somebody has the makings of a great truck!
Two door,
Best of both worlds. Yard art today, killer project tomorrow
Citation
Indy
It's interesting to see many of these pictures. While I have strong memories of my father's F350 (it was sold perhaps just over a decade back), many of these trucks have different details that I'm noticing.
One example is the factory steel wheels. Dad's truck started off as a crewcab non-dually so it didn't have the deeply dished front wheels or extended hubs. This is the wrong color but otherwise looks a lot like Dad's
At some point Dad had it converted to a dually. Perhaps because it started with the standard axles the rear wheels were offset inward. A typical dually has the inside rears inline with the fronts and the outer wheels just stick out. With Dad's I'm guessing the inside wheels were moved 1/2 a tire width inboard. Net result was he had to cut holes in the bed and add some heavy rubber material to make a larger wheel well. At some point the entire bed was replaced with a work/utility type bed.
I still remember how far you had to move the shifter from 1st to 2nd. Longest throw ever!
R
RivennHewn
PNW
Citation,
I know the trucks sold as dually/cab and chassis had frames that are narrower.
I believe the axles are narrower too, but I may be wrong on that.
As far as the shifter throw, that’s half the fun of driving these old trucks!
Monza Harry
Windsor ON
Citation,
There were some trucks built with the rear dually's as narrow as the single tire version's [~3" maybe wider] for things like "Glass Trucks" where their whole load was basically outside the wheels. That long first makes me think that ****** was a 3 speed + Creeper gear, like a SM420 or SM 465 [sub 6:1 creeper gear, first was in the 3:1 range that throw was to remind you if you let out the clutch you were going to stop LOL] Our neighbor had one like that with the 300 inch six and an off-road package that truck was tall probably 2' to the rockers, it was a stick but I was young and didn't know anything about it then except Ohhh. 4 Speed. Harry
Citation
Indy
The 1st gear was certainly optional when the truck was empty. I don't know the rear end ratio but it was long. I believe it was what ever 4spd that would have come with the ~400 CI V8. It's just that the rear end ratio was setup for heavy trailer work. I think the duallies were added when Dad got a 5th wheel trailer. Even that was a bit unusual as most 5th wheels have a pin on the trailer and the hitch plate in the bed. This one was reversed. That was handy as it meant you only had to fold the pin into the bed vs having to remove the hitch assembly.
BTW, while noting the very long shifts, I really liked the mechanical feel of that old transmission. It didn't want to be shifted quickly but had really gratifying clicks and notches when you worked at its pace.
R
RivennHewn
PNW
Thanks Monza and Citation,
Long term goal is a 5 speed ******. Most likely a ZF5.
I think I’ll miss the feel of the shifter, and I don’t care for the straight handled shifters of the 90’s trucks.
Going to have to find a way to keep the original bent shifter handle.
Sure will be nice to have another gear!
R
RivennHewn
PNW
Got bored working on the house, shop, boat and yard work.
Decided it was a nice day for a drive.
There’s a great lookout from the top of Mt. Erie near Anacortes, about half an hour from the house.
Fairly steep and curvy road to the top, and a great view!
R
RivennHewn
PNW
Erie is only about 1300 ft.
Picture is looking South, but with a little hiking you get spectacular views all the way around.
R
RivennHewn
PNW
Thinking I might need some chains.
R
RivennHewn
PNW
Knocker, Seagoon,
As a kid in Alaska, I used to chain up my dad’s old flatbed and plow driveways.
Felt like that truck could do anything.
400/4spd. With a load of frozen sand on the back.
Easy money.
R
RivennHewn
PNW
What do I got going on here?
Been a bit of a hard start lately, but I’ve never seen this before.
nsula_country
Northwestern Louisiana
Got HOT! :rocketwho
I have a lifted electric golf cart. Have had vertical learning curve with batteries and cables over the years.
Parts houses (around here) only carry small, 4 ga cables.
I keep a supply of 2ga welding cables and lugs. Roll my own!
CT
bulletpruf
San Antonio
I'm always buying battery cables and tired of paying too much for something I can do myself, and it's great to have an excuse to buy more tools. For the skinny on what to do/what to use, the powerboating folks are a great source of knowledge. My input:
FTX crimpers are the best for the money, but they're about $150. Hammer crimpers can be had for $20 on Amazon, but it's not as good of a crimp. I have both.
Best lugs are supposed to be FTZ Power Lugs. I have some 2/0 lugs for a 3/8 post in the mail; need to re-do terminals on my 1999 Super Duty 7.3.
Ancor tinned copper wire is supposed to be the best.
Use military terminals. I bought some on eBay.
Use high quality adhesive lined shrink wrap.
danski0224
Near Naperville, IL
CE Auto Electric supply.
I like buying tools like anyone else, but it was much more practical to have these guys make the cables for me, especially for one project.
If I had a slew of cables to make up, that's when I might buy the stuff to make my own.
R
RivennHewn
PNW
Had some fun working with my neighbors cleaning and maintaining the community boat ramp today.
hauled a few loads of crushed rock to fill in the gaps between the concrete slabs.
tide was up a bit, so we couldn’t get the lower end, so we’ll be back later tonight.
want to be finished before the weekend, so people can use it.
boating season is here!
R
RivennHewn
PNW
Been awhile.
had to take a forced break for a well written, humorous post.
hope y’all caught it before it went away😜
Gave me some time to focus on getting some work done on the Shoreline skiff.
Everything inside is done, and ready for paint.
No more caulking and sanding!
R
RivennHewn
PNW
Happened along a small town car show today.
Lots of nice cars.
I usually miss shows do to work and other obligations of my time.
great day to stroll through and enjoy other people’s hard work
R
RivennHewn
PNW
The moon came up over the ol ‘77
Mallen
Sweet project!
For sure upgrade to disc brakes. You'll be glad you did.
Nothing wrong with drum brakes. They sold trucks with 4 wheel drum brakes at least I to the 90s. They STILL sell vehicles with drums on the rears. Fix the drums. Then fix all the other things that need to be fixed to safely drive it around. Then start upgrading as you see fit. Otherwise it will spend the rest of it's existance as a lawn ornament.
R
RivennHewn
PNW
It’s roadworthy now.
Might be making the 120 mile round trip to clear out the last of my lumber/wood shed at the old house this week.
