7x12 bandsaw
goldie lox
Picked up a horizontal 7x12 bandsaw for a good price, the only thing wrong is when it cuts it has a run out of .125 or so. Is this caused by a worn blade or something worse
454ragtop
Carver, MA
Try a new blade before anything else, often they lose the set on 1 side and cut crooked. See if there is any play or slop in the frame pivot.
G
goldie lox
I looked at the settings and all seem good, it reminds me of a chainsaw when it looses teeth and halfway through the wood it angles away
marinusdees
Edgewood, Washington
The most common cause of these saws cutting crooked(ly) is excessive downward pressure. This is assuming a new blade and guide bearings lubed and adjusted. There are a number of sites devoted to these saws. You'd be surprised what you can learn there.
