Depends on the blast cabinet and gun, likely the compressor will run continuously in most cases.
Even the HF a portable blaster says 6 CFM @ 60 PSI; 25 CFM @ 125 PSI
Pressure tank vs gravity feed ?……… Air Consumption: 6-25 CFM,
Lower CFM is going to slow………..car frame is going to take a while.
MADE in USA - FULLY ASSEMBLED! 34" WIDE, 22" deep, 20-1/2" high work area - top-load design saves 22" of valuable floor space in your shop! Includes powerful Vac-55 HEPA Vacuum for dust removal! Our Slant Top 33V Top-Load is easy to use - flip up top-loading door and pour abrasive...
www.tptools.com
The pressure washer sand blasters are very temperamental……….some report OK results by making the “sand” a slurry mix. They can be slow and messy…….but all blasting has a mess, dirt and dust factor.
