8" or 6" bench grinder
79mudbugg
nc
so in the market for a bench grinder!!! just curious what's the difference??? I read something about ones better with sharping wood tools?? any input would be great!!!! thanks
jkwilson
SW Indiana
With a 6" grinder, the motor is always in the way because the wheel is about the same diameter as the motor.
dmcintosh
Smyrna, DE
What about one of the newer style belt sander/grinder combos? Or, are you looking specifically for a grinder? I'm a huge fan of whatever I can find used? I am not a professional so I don't require professional tools, but do buy the best quality I can afford.
Gizmosity
SW Wisconsin
You might be thinking of a grinder that spins at 1725rpm for wood tools. Most of the ones you will find for sale are at 3650rpm. I run a 1725rpm grinder with 6" white oxide wheels for sharpening. I like the smaller diameter wheels when putting the hollow grind on chisels and especially plane blades. An 8" wheel creates a near flat surface, where a 6" creates the wanted "hollow" making sharpening easier.
For general shop use I use a standard 3650rpm grinder with 8" wheels.
PT Doc
Look at belt grinders before deciding on a bench grinder.
79mudbugg
nc
hate to sound like a newb but what would a belt sander be good for around the shop?? guess I tinker with everything just like normal people?? I don't do wood working so....
PT Doc
I definitely did not say belt sander. That's a poor tool for what are likely looking to accomplish. Look up belt grinders on the web and YouTube. GRINDER!
Norcal
Look for a old Baldor, Rockwell/Delta, & some other OLDER grinders, stay away from ChiCom garbage, the vintage machines are so much better then what is avail today other then Baldor.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A couple years back I bought a combo belt sander/disc sander. I very rarely use my bench grinder except for the wire wheel I put on it. I use the belt sander for deburring metal rod, if I have a piece of wood I want to bevel the edge, beveling the edge on a piece of metal, sharpening lawn mower blades.........There isn't a week that goes by that i don't use it for something. The bench grinder, may set for weeks and never get used, unless like I said to use the wire brush on it.
Jack Olsen
Los Angeles
I'd look at amps before the diameter, all else being equal. Bogging down is a nuisance.
I agree that a belt/disc sander is a surprisingly useful tool. Especially for metal.
unisawone
Owatonna, Mn.
Look for a smooth running good quality. I have both sizes, both are Wissotas great grinders if you can find them. I agree with the belt comment though, use that much more than a grinder. Good luck
finn
The UP, God's country
I've got a 6", & an 8" grinder along with a cheap Jet belt/disc sander. If I could keep only one it would be the sander, followed closely by the 8' grinder.
One also needs a dedicated wire wheel, but safety glasses are mandatory with one.
7th Kahuna
Los Angeles, CA
Many good points. When it comes to sharpening woodworking tools, heat is your enemy. The slower the wheel, the slower the heat builds up. As it was explained to me; an 8" wheel is turning slower at its outside edge than a 6" and of course a 1725 rpm motor is turning slower than a 3450. I can't personally say whether there is that great a difference between 6" and 8". I have always used an 8". Beyond that, look for an older grinder, the quality is better for the price, and when sharpening keep water nearby or look for a grinder with a built in 'cup'.
EDIT: Ah the perils of accepting rules without thinking about them. As finn noted the 8" wheel has a higher face speed than the 6". :thumbup: Maybe I remembered the reason wrong. Mr. Holland, who I learned sharpening from, definitely preferred the 8" wheel, he also liked to freehand sharpen which allowed him to feel the heat in his finger before it built up too much in the blade. When he used a support, it was a thick piece of steel which acted as a heat sink and kept the blade cooler. Now I have to do some research. :lol:
exmaxima1
Midwest
Absolutely! Once you use a belt grinder you will never use a wheel grinder again. Far superior for most applications.
BTW, variable speed is a good option for blade sharpening/honing.
7th Kahuna
Los Angeles, CA
Keep in mind, if you are looking for the best quality cutting edge, you are most likely only using the grinder to 'reset' the tool, as when repairing a damaged iron or when changing the angle of cut. After that, you are going to take it to your oil or water stones to finish it. Of course there are some specialized wheels out there but I don't think that is what we are talking about here.
