8 point sockets
plinker
Northern Wi
These are the only socket that will remove frozen in pipe plugs without rounding them off. If they get rounded you'll need a "bolt out" socket to remove them.
Some set screws also have a square head.
dxdexter
in a pinch you can also use them with a suitable size of solid square stock to make extra long socket extensions.
chad s
Baltimore, MD
8 point sockets are to 4 pt sockets, what 12 pt are to 6 pt sockets. Has any company made 4 point sockets anytime recently (like the last 30 years)?
chad s
Baltimore, MD
Snap on make 4-point sockets. (Pipe plug sockets.)
I always thought a pipe plug socket was a make square end, like the socket on the left.
wilbilt
NorCal
Automotive plugs are usually an internal square, plumbing plugs generally are an external square.
MarkH
Kansas
Lots of our older ag equipment when I started had square nuts on them. We do not use 8 pts much anymore, but at one time we had to have them all over.
krusty the clown
Member Emeritus
niangua, mo
I find it funny that Snap-on sells a 1/2" square external (male) drain plug socket for Cummins drain plugs.
they didn't think to just stick an extension in there?
i'll probably still buy one..
some pipe plugs are not deep enough for an extension to go in past where the hole is bored for the ball. i tried it once years ago, the plug was tight and the extension twisted off right at the detent.
Uncle Buck
Kansas
I have them to about an 1" and every now and then something comes up and I use one or another of them.
Moose-LandTran
The Brink of Insanity (England)
I did once come across that problem. it was the drain plug for an old Jaguar diff. it had a little surface rust and the extension didn't want to go in because of the ball.
The solution? i stuck the square drive of my IR 2135 impact gun in there. a little tap from a soft-faced dead-blow helped it in and i rattled it out gently. worked a treat.
eschoendorff
They also make some big ones for budd wheels or something. maybe 3/4" or 1" drive.
Yup... just bought a 6mm for teh lugs on drums (secure the hoop that holds the drum head on). the Snap On was pricey, but not as expensive as the POS made in China Ludwig ratcheting tool (that freezes up) made especially for the job.... what a load of ****.
Merkava_4
Clovis, CA.
I've got a 3/8" 8pt. socket that's designated for removing Briggs & Stratton oil drain plugs, but I always grab a 12pt. 7/16" because I think it's more fun; is that freaking strange or what? :eyecrazy:
Brandon_Lutz
Forest Hill, Louisiana
We only have a few 8 point sockets on the farm. We use them to quickly take off drain plugs on various pieces of ag equipment. For example, our fold up Bush Hog shredder has 3 gear boxes on it that drive all of the blades. Each box has the square drain plug for adding or draining fluid.
We could use an adjustable wrench, but the sockets are quicker.
Abodyracer
Lincoln, NE
At one time I had locking lug nuts on one of my vehicles and I lost the key. A tch at a tire store hammered an 8 point socket onto the lug to remove it. A hammer and a punch drove the lug ourt of the socket after removal.
Lots of antique equipment used square fastners.
Craftsman still makes 8 point sockets. http://www.sears.com/shc/s/s_10153_12605_Tools_Mechanics+Tools_Sockets?keyword=sockets&filter=Brand%7CCraftsman&viewItems=20&pageNum=1&sortOption=ORIGINAL_SORT_ORDER#viewItems=20&pageNum=1&sortOption=ORIGINAL_SORT_ORDER&&filter=Brand|Craftsman^Contact+Points|8+point&lastFilter=Contact+Points
Moose-LandTran
That blows my mind.
I'm more one of those "right tool for the job" guys, i love to have all the special sockets for stuff. I always use them over other alternatives. I've spent this much on them, i'm gonna get my money's worth!
One of many tyre shop tricks to remove locking nuts. Usually, we just hammer on a 12-point because they're readily available and they do the job just as well. You can also "stretch" locking nuts/bolts to get them off. But i can't share all my secrets. :)
