widerberg
Hi, everyone
I've run out of space in my attached and, as money's a bit tight, I've decided to build a small 8ft x 8ft shed in the back yard. My initial shed dimensions were much bigger, but I think the 8x8 will suit my needs for now.
Lots of plans online call for 2x6 support and end boards under the surface boards (floor). For a shed this size, can I get away with 2x4s?
I'll be storing a hard top for a Triumph Spitfire, some car doors, and a scooter (about 200 lbs) or two in there.
For flooring, I'd thought about 3/4" pressure treated plywood with 3/4" tongue and groove planking on top (for the look).
The whole thing is going to sit on 15 of those Dek-Block concrete piers you can buy at Home Depot.
Will 2x4s work, or should I really go with 2x6s? I plan on having them on 12" or 16" centers, rather than the usual 24".
Any advice would be appreciate. Thanks
