80 gallon air compressor Amazon
95vette
Hello, Check the Ingersoll Rand 5 horse 80 gallon at Tractor Supply, usually around same price and you can see what you are getting. Jim
The Cobbler
no where on the screen that I look at does it give the hP
here are the specs copied
part Number XC802100
Item Weight 400 pounds
Package Dimensions 72 x 36 x 31 inches
Item model number XC802100
Size 80 Gallon
Color Blue
Item Package Quantity 1
Maximum Pressure 12.06 bar
Included Components Stationary Compressor
Batteries Required? No
Warranty Description 3 Year Limited
Additional Information
ASIN B07RHCD115
Customer Reviews Be the first to review this item
Digital4n6
Glen Allen, VA
I don't see where it says 5 hp.. just says "The 240 volt, running HP, heavy-duty induction motor "
If you scroll halfway down the product page, you should be able to see the "Product description" (I pasted it below). Can also jump there by viewing the top of the page under the title where it has bulleted points with a link to "See more product details". :thumbup:
Product description
The Campbell Hausfeld, 80 gallon, 2 stage, 5HP electric air compressor (XC802100) features a cast iron, oil lubricated 2 stage pump for 5000 hours of increased longevity and reduced noise. Boasting 175 PSI max pressure and 15.8 CFM at 90 PSI, this stationary air compressor allows the user optimum tool performance. The 80 gallon ASME vertical tank design is ideal for garage and workshop applications with a space-saving footprint. Needing a 230V power supply, The XC802100 is ideal for rotating tires, repairing engines, grinding, sanding, painting, nailing and more. Finish your projects faster and easier with Campbell Hausfeld. The air power expert.
beelsr
NE PA, USA
there may be more, i didn't look for more than a than 15-20... seconds.
80 Gallon 2 Stage Air Compressor (XC802100)
The 80 gallon 2 Stage Air Compressor is ideal for tackling paint spraying, inflation, sanding, grinding, stapling, nailing, and bolting projects
The 240 volt, running 5 HP, heavy-duty induction motor creates maximum pressure to operate a wider range of tools while maintaining longer compressor run times (no power cord)
Question: What is the horsepower?
Answer: It is 5 HP
By Campbell Hausfeld MANUFACTURER on July 29, 2019
beelsr
NE PA, USA
reading-not-required version...
  • Amazon_com_ Campbell Hausfeld 80 gallon 2 Stage Air Compressor (XC802100), Blue_ Home Improvemen.jpg
C
Crabman
Alexandria, VA/Dameron, MD
it does say 5hp
I also looked at the manufacturer website.
Does anyone have experience with this compressor?
Why is the TSC IR better?
I was not trying to start a reading comprehension exam...
XJPat
Central Jersey, Merica
I believe people generally lean towards the Tractor Supply Ingersoll because you get to see it before you buy/pickup. You know hopefully avoid shipping damages.
Sent from my SCH-I545 using Tapatalk
beelsr
NE PA, USA
not trying to be a smart-***, but...
do you not have a PageDown key? The space bar should work as well - to page down. I see spaces in your post so I surmise that key works for you. or..... just look at the screen capture in post #9.
don't know what else to say....
I have the CH 80 gallon. It's 19-20 years old. It think I paid $400 for it. I remember it being significantly cheaper than the IR, which I wanted but couldn't justify at the time. It came in the back of an 18 wheeler and the driver hand-trucked it up the driveway. 3 houses later...
it's still on the pallet. I put synthetic in it, replaced with drain valve with an HF blowgun on braided clear hose and it just runs.
You get to see the IR unit in person but have to get it home. Amazon delivers and has a generous return policy.
