crocket468
- Joined
- Aug 12, 2015
- Messages
- 66
I'm going to start this out with a little chest thumping as my luck with project buys rarely end in my favor.
I ran across this on CL the other night and immediately set up an appointment with the seller to check it out.
http://raleigh.craigslist.org/art/5462244827.html
80 gal 6.5hp 2 stage Devilbliss "Air America" compressor $100. Posted as "metal for art"
Seller stated that the compressor was pulled out of service and replaced. It was stored under a shelter, a bearing in the motor seized up so they had the motor rebuilt. After the motor was replaced the pump would not build pressure. He was selling it as scrap for art because the pump wasn't working, said he had no idea someone would want to fix it.
I take a gamble (cant test anything while there), pump feels ok on rotation, no play in the crank shaft, just dirty. I figure a a new valve body will be needed. The tank has surface rust from being stored under the shelter where the ground was frequently damp. Ball peen test on all the surface rust rang true so I drug it home. Tank shows date of 1996. I figure I've thrown away $100 on less...
I get it home and decide to test the motor before I go any farther, pull the pulley off and and notice there is no key in the shaft slot.
Motor spins right up with no issues. Made a key to try the pump before I go any further. I fired her up and in less than 6 minutes, she was sitting nicely at 135 psi.
Now that that's out of the way....
This brings me to my main question, I'm going to start disassembling the unit to clean everything and repaint the tank (or powder coat it). The ASME tag has rust around it and looks like possibly under it as well, I plan to treat all areas with rust converter prior to refinish but I'm curious to know if it would cause me any issues to remove the ASME tag to make sure all metal under it is clean then reapplying the tag with epoxy. Id obviously take my time with the tag removal being careful to keep the metal cool and not to remove any material from the tank it self. I'll probably hand file the welds down after.
Have any of you done something similar? If so, how did it turn out?
