80 vs 90 tooth blade on miter saw?
marlinspike
Virginia
Given my experience with them on the table saw, I am a big believer in Forrest blades. I am buying a miter saw, and want to put a Chopmaster blade on it. Am I really going to notice a downside to the 90 teeth of the Signature line to the 80 teeth of the standard? I feel like once you're that high in tooth count a few fewer can't hurt anything, but never having used one maybe I'm wrong.
cheechi
Triad, NC
what species of woods? whats the typical size of cuts? what saw?
I have a Dewalt 80T and a CMT 96T and I bet even I couldn't tell the difference in the cut between the two in anything I've done.
rlitman
Long Island
From this page:
http://www.forrestblades.com/chopmaster/
The 80 is ATBR 4+1, while the 90 is ATBR 2+1.
What that means is the 80 will have 4 angled teeth, then one raker, while the 90 will have 2 angled teeth followed by one raker.
For strictly cross cutting (90 degrees), I'd expect a cleaner cut with the 80. For miter cuts, the 90 might be a LITTLE better.
exmaxima1
Midwest
The higher tooth count will usually yield a cleaner cut. Slower and harder though.
Definitely SLOWER. The more teeth, the less gullet space to haul away the waste. The thicker the stock, the less teeth you need. Ideally you have at least 2 teeth in contact with the cutting line at all times.
tarbellb
Oregon
Ive only found big issues in high tooth count blades when cutting thick + hard materials like Oak. More teeth created to much friction and caused burning.
With a quality blade like a Forrest I bet you could easily get away with 80 and never notice a difference in really fine cuts.
