drmanhattan
Hi there,
Apologies if this in the wrong thread. I recently picked up an old (80's I think?) heavy-duty Milwaukee sawzall model 6507(631B, I also think?). I grabbed it for $10 at an estate sale as I really just wanted the metal box but it came with the saw so I figured I could maybe tinker around with it and see if I can get it working again?
When I plug it in, the motor hums but the chuck doesn't move. I take it apart and pull the front end out and it looks like this is where the problem is. Using this video as a reference (granted it's a much older model than mine)
(he examines the piece I'm talking about at the 20:12 mark)
, it looks like the gear should easily spin and move everything around when it's working well. The gear on mine barely moves and nothing else does. I believe the top shaft is bent slightly, but, considering the bearing was machined at an angle so it works with the wobble plate, I can't 100% tell? Also, the part the guy in the video has conveniently has screws everywhere so his easily comes apart. My version appears more machined so, short of grinding stuff off, there's no way to get further into the mechanism.
I'm attaching pictures below if anyone has any thoughts about this and getting the chuck to move again. Again, my outlay was $10 so I may just grind into it anyway, toss the saw, and use the metal box as a toolbox like I originally intended.
Thanks
Thanks
