Above 1200 Sq/FT 86's 20HP shop
86turbodsl
Ordered a new control board for the 3d printer, and then got back to work in the shop. Temp was way down from not running the boiler a couple of days, so i let it run most of the weekend catching up.
Here's the left pipe all tacked up and sitting in position.
I think the routing looks good, very similar to the stock downpipes.
Good clearance with the crossmembers.
The flange weld with 309L, mild steel flange, and stainless pipe. There was a good bit of gap between them. It was a very tricky weld. I had to dump a ton of heat into the flange and just barely nick the pipe or it would melt. Then using a modified laywire technique, i shoved a ton of 309 into the puddle, keeping it biased towards the pipe so it would cool it off. The downside is that weld is a lot bigger and hotter than it should have been, and the exhaust manifold is going to interfere. There's a cone built right into the manifold exit that i am going to have to grind down to get this to sit flat. I suspect that might affect sealing but not sure. For right now, i will call it a win and just use some copper rtv if needed. Still need to add the o2 bung and fill in the backside of the flange with silicon bronze. Then it's pretty much done.
Hopefully i can keep the shop temp up better this week. I didn't babysit as much as usual last week since it was warmer.
86turbodsl
Seems we have some snow coming in this week, so i will be at the office M,T,F and home W,Th. I could get used to the flex thing.
I ordered a Hougen annular cutter set, so should be able to cut O2 bung holes pretty easy. The amount of tools i'm buying for this exhaust stuff is kinda crazy. But i suspect i save the money i would have spent getting them made.. we will see.
Bob Heine
Boca Raton, Florida
@86turbodsl, I asked a welding shop for a price on two custom stainless header pipes. For the price they quoted I bought a welder, tank of 98%/2% Ar/CO2 and a spool of stainless MIG wire. It didn't cover the two mandrel U-bends, V-band clamps, reducers and stainless header flanges but I expect they would have charged me extra for that.
86turbodsl
Lol. Point taken. And i'll use the annular cutters on other stuff too... ;)
86turbodsl
Lack of posting lately. Sidetracked a bit. I did get my Hougen annular cutters this weekend, and they work AWESOME. O2 holes cut out and 1st downpipe completely finished. Working on #2. I suspect the Hougens become my new favorite hole drills. PERFECT holes. Easy.
I did have to grind down the exhaust manifold to get the new pipe to sit flat. And i managed to ding up the studs around that area, so i need to get new studs made. Threaded rod should work. Hopefully i can get that pipe mounted tonight.
The drive to work was interesting...
Lack of road salt leads to 6 Tractor trailer pile up on WB I-94 @ Chelsea, including miles of backed up vehicles followed by cars turned around and heading EASTBOUND on WB I94, something you never see, and to top it all off, at the rest stop near Chelsea stopped on the shoulder, a MOTORCYCLIST ON HIS BIKE stopped watching traffic roll by. It's 24F out.
Wow.
ClappedOutBport
Annular cutters also make superb pipe notchers if you have a mill or very stiff drill press. I've used up to 3 3/8", lovely tools!
Also good for making thin rounds for various parts, like capping tubes.
86turbodsl
The machinist at work asked me why i didn't buy the set up to 1.5". Because i'm not made of money! I have the master set up to 3/4"
86turbodsl
I heard from my bro in DFW also, he said the place was shut down with icy roads. Stay safe!
In other news, i bolted the first downpipe on for good last night and started on the 2nd. And annular cutters, where have you been all my life?? Amazing holes. 1/4" plate flanges, cut perfect holes in seconds.
bulletpruf
San Antonio
Schools closed in San Antonio for the second day because of potential for icy roads.
A bit of snow on the ground here in Virginia, too. First white stuff this year.
83VillageRepair
Merkel, Texas
Work is going to be fun today. I wonder how well annular cutters would work notching structural pipe
jbmatth
Northern Ok.
Just be really careful using them, keep cutting, don't back out of the cut until complete. I learned this lesson the hard way drilling my welding table, broke 3, found out my mistake the next day talking to a machinist at work. Expensive lesson.
JB
86turbodsl
Got the exhaust manifold ground flat last night, bolted on the new flange, and got the first section of pipe tacked up. Basically making the mirror image of the first one. Once it's done and bolted on, the engine can go back in. Should go a lot faster then. Custom fab is always way slower than bolt ons.
86turbodsl
No pics sadly as it was late and i forgot to take my camera, but the downpipes are both done and installed, the last few bits of harness repair are done, and i'm working on bolting bits to the engine getting ready to install. I still need to flip the cart around and lift the engine with the forklift to get the subframe and mounts reinstalled. Also rebuilt the shifter and installed that as well. Getting a lot closer!
I've also progressed on my TIG technique to the point i can join piping without filler if i wish. Autogenous is quite neat. Just move the torch along the joint and watch it flow together. On recommendations of my welder friend, i am avoiding it most of the time though.
86turbodsl
Here's where we are now: Getting ready to put her in.
In other news, my daughter's Audi exhaust failed. I have a new one to put on, but the front half of it isn't built yet. So i had to order all that yesterday, and it will be a mad scramble to get it done over a weekend since i have to take another car down to do it.
That front hunk there was from the other car. It was on an S4 w/big turbos. Obviously i do not have turbos on the car, since it's an A4, but the exhaust was cheap-ish and stainless and local. So we'll make it work.
86turbodsl
Guys, I am soooooo tired of car repairs. I actually want to work on the shop, not all this foolishness.
Jobs are stacking up!
The stainless stuff shows up today. I got a good nights' sleep, so that helped.
In other news, i just discovered HGR now has a Detroit location. I did NOT need to know that....
Strouty
Southern Maine
How hard is it to put the bend in the pipes? I can see what you are talking about, but not sure how big of a deal it will be or not be. Assuming no easy way to deal with it after it is in the chassis?
86turbodsl
Pull them back off and splice in a chunk of elbow. I went out and pulled them up, i think there's enough room to flex up and be ok. Hard to tell for sure while it's out of the car. If i have to fix it after engine goes in, it'll **** a bit, but at least i have a lift and the cats aren't in the way anymore. I should be able to tell at that point. The flex joints are after the brackets to the transmission.
Strouty
Southern Maine
So that corrugated piece has no flex? It is definitely a tough call, most of the cars I have dealt with have a stainless braided flex section that makes for a lot of room to adjust.
86turbodsl
Yes, the corrugated sections are the flex pipes. They don't have the braid over them like a lot of them do. These ones are supposed to be more robust than the usual braided ones. Time will tell on that front.
Monza Harry
Windsor ON
Guys, I am soooooo tired of car repairs......
I hear you on that one, my daily driver is going to be 22 years old sometime this year! The needed repairs are multiplying faster that rabbits multiply.
Now for HGR, due tell (share some details Please), and this does sound bad in the best way possible! Harry OH GOOGLE SMFH :lol_hitti
86turbodsl
HGR started in Euclid, OH. Think dirt cheap tools. AFTER they sit there a while. They are all on consignment. For instance, my big bandsaw was 400 there, my two syncrowaves were 150 and 100 there. And so on...
Monza Harry
Windsor ON
Thank You, I was looking for their location, after careful scrutiny I found their location, pretty much between the Suburban Collection Show Place and KITTS, [45 minutes from here] and their hours ****, no Saturdays, I have tomorrow off and Monday. Friday no suitable wheels to go there, Monday SWMBO's birthday, somehow I don't think I can sell that trip as "for her" I might try, but I better find my "cup" first! Harry LOL!
86turbodsl
I haven't been over to the Detroit location yet, i did an online search, seems to be mostly big VMC's so far. I like Euclid for the smaller stuff. I'm not looking to buy a 15K VMC.
83VillageRepair
Merkel, Texas
They ship reasonably as well. I bought my Miller Trailblazer from them and even with shipping was about half of what I could find around here
