86turbodsl
So with the warmer weather, i've been able to get more shop time by a bit and have been working on the burner assembly. I started out with design of a burner plate and flange on the cnc plasma. I'm following the basic design of gerry'sdiy on youtube. But refining a bit. The burner tube is 1/2 copper with an elbow brazed with silphos15 and the outer tube is 1.25in black pipe. I had a buddy at work put a hole in the elbow to fit the copper and tig on a fitting for gas. the inner copper pipe delivers the oil in a small stream to the pot and the black pipe delivers combustion air from outside via the blower on the wall. I cut the black pipe to a 45 degree and welded together with 7018.
The gas pilot valve will probably get put on the burner flange in the boiler, and i hope to use it to light a copper line with holes in it that will run down to the bottom of the burner. Still not sure how well that holds up in the inferno i expect.
