83VillageRepair
I am just kidding. When I was stationed in Italy they used DDT for everythingWhere are you finding THAT? Pretty much nothing (legal) but heat kills those things. They are everywhere now.
First thing i learned when i moved to the country was that normal homeowner stuff didn't hold up. It's been commercial or industrial equipment since then. We had a Murray we bought from my Grandmother when we moved here. Little thing, as they had a little yard. Lasted about a year. I sold it to somebody for $50 that fall. I was buying deck spindles in bulk. Then i used the bushog for a while. Finally found a 6' finish mower for my big tractor, but that thing takes a TON of power to run, so the tractor at 30hp is a little on the light side. It's probably just too tired for that mower. So that sits now. I bought a diesel Yanmar GT14 thinking it would fit the bill with a 48" cut, but once i tore into it, i found the pto clutch was bad, got that rebuilt, then found the end of the crankshaft is bent from when the clutch went bad. It threw a ujoint. New cranks are unavailable, and i can't find a crank grinder that will grind on a taper. I suspect if i want that fixed, i will need to weld it up and turn in the lathe myself. So it sits. Three years ago, we bought a White FR12 zero turn mower. That thing was great for a summer, until my kid was mowing in a rough patch, hit a bump, the machine bounced and stopped dead. I worked on that thing for days. Swapped starters, batteries, did all kinds of stuff. It was locked up solid. So dragged it over to the shop, hoisted the engine out, full teardown to find it completely fine. What had happened, was a chunk of connecting rod had bounced up and wedged itself between the crank counterweight and the block. What was interesting was that both con rods were INTACT. The chunk of rod must have been from a previous engine disaster. Thing is, you can't do an in-frame in that mower. So who would pull an engine, rebuild it and LEAVE THE CHUNKS OF ROD IN IT??? I have no idea. Then we bought an M&W zero turn couple years ago, it's basically same as the White, but with bigger engine, 60" deck and MUCH nicer hydraulics. The White had the integrated pump motors like Grasshopper/Woods. The M&W is a more advanced/expensive model that has discrete pumps and wheel motors. No chain drives, just all hydro. That thing, if i get it going, will be SWEET. I also have the Woods zero turn that i bought with a blown engine, that has the rear engine, and will get the 2cyl Yanmar when i get to it, if ever. I suspect that rising fuel prices will force me into it at some point, since diesel equipment gets about 3X the fuel economy of anything gasoline.What's the latest status on your kid's truck and the mower? I seem to recall a mower project involving an engine, but the details are a bit murky...
I used to want a large lot with grass, but after my b-in-law's escapades with mowing four acres, that desire has been squashed..... seeing as I'm the one that does the mower fixing.... Crapsman engine rebuild.... Then finally got him into a Kubota F2400 and had to rebuild the entire mower deck with new bearings, etc, then rebuild the rear axle drive spindles, electrical issues, etc.... But overall, the Kubota get's the job done way better than the 48" crapsman mower....
How have i never seen this movie??? Awesome scene! Yes, i could do that, but sounds like a lot of work lol.
For a while when i couldn't find a mower i liked, i had a pipe dream about building a zero turn power unit out of a Tempo diesel engine and attaching it to my 6' finish mower. Complete with cab and a/c of course. Life is just too short....
I'm in this camp.Trust me, I wasn't advocating only buying new. I rarely do that. However, I think the key is having a realistic understanding of the time and money to repair a "great" deal..... In many cases, spending a little more money upfront will actually save a lot down the road. Especially if it frees up your time to do something more profitable (whether that means actual cash into your pocket, or simply more mentally satisfying...)
I will say too, having a wide array of interests, spreads the money availability a bit thin.....
Regardless, I'm only suggesting to pick your projects carefully. I get the backlog.......
Nope, you are not alone. Last night i put the engine and ****** together. Still got an issue or two to work out, but almost there.
Well, there's typically 2 types of sales in this area:Trust me, I wasn't advocating only buying new. I rarely do that. However, I think the key is having a realistic understanding of the time and money to repair a "great" deal..... In many cases, spending a little more money upfront will actually save a lot down the road. Especially if it frees up your time to do something more profitable (whether that means actual cash into your pocket, or simply more mentally satisfying...)
it's a zf5. 5.0 EFI. We got it in last night. Switched over to the forklift, it was a little light in the rear, but i had the missus stand on it for more counterweight. harrumph. The kid bitched the whole time. He's not cut out for this. I just work through things. Now i'm stuck at the crossmember, which is different, so i'm going to steal one from one of the parts trucks.
As far as projects go, i really really like zero turns. But i don't have the cash for a new one. Now things have gotten considerably better in cashflow the last few years, and i've built some nest egg, but i don't have much desire to blow it all on a new mower, especially since i don't have any desire at all to have a manicured lawn like the neighbors. Those guys are nuts. They even mow into my yard if i let it go too long. I've told them to stop, but they are so nuts about it that they don't listen to me. I get the thing where it makes sense to pick projects carefully, and i'm trying to get to that point. BUT the issues don't go away in the meantime. If the lawn gets too long, the insects get out of control, and they start moving into the house. All of these issues are why we have been mowing with the bushog for years. But it's not a very good mower frankly.
Probably, if my wife hadn't been into horses, i would be living in a much smaller lot somewhere with a much smaller backlog of projects. We're essentially a mini-farm. And i work in the city, 62 miles away. And salaried, where they expect overtime a lot of the time. So i am spread pretty thin. My goals for my life do not include a manicured lawn, making neighbors happy, or anything beyond staying out of trouble and putting away a little cash to be able to fund my hobbies. I'm getting older, and there's only so much time left. So i am working towards cherry picking jobs. Just not there yet.
And no, i do not play the lottery. There would be no point right?? lol.
You and nearly everyone else.I'm so sick of work drama.
2 years stuck at home makes me realize i just don't want an office gig anymore.
Anybody close to retirement wants to stay home, including me ......no office job and worked at work the whole time.I'm so sick of work drama.
I'm not that close to retirement, but would sure like to. I've never been that good at office drama/interpersonal stuff.Anybody close to retirement wants to stay home, including me ......no office job and worked at work the whole time.
How's your back doing today?I strained my back this weekend as well and it just makes life miserable. I've been applying ice packs in 30 minute intervals, but so far not a lot of improvement...
The challenge can be some of the "old-school" managers who feel the need to "see" their people in order to manage...
