Hmm. I did plan to use the plc to limit on time to the ssr, and I'm not sure where to get a ptc heater. I'm set up for a water heater element at present.
Edit: i found some documentation that PTC heaters max out around 160F, i need to be able to go higher for some oils.
Sent from my LG-TP450 using Tapatalk
I have a heatsinked 100W PTC enclosure heater that definitely reaches >212F sufrace temp as evidenced by water boiling when I splash it. power output has dropped significantly by that point (starts out around 500W, drops off as it gets hotter).
it's not this one but shows the temp/wattage curve:
https://www.thorlabs.com/thorproduc...MIi432ncfZ3gIVTb7ACh3mtQRPEAQYBCABEgJu-vD_BwE
here's the one I have - the 100W model. 200C temp
https://www.omega.com/heaters/pdf/NCH-37000.pdf
