@Bimmer, you must have a low temp / high efficiency boiler. 120-140F is down around condensation temps for gas, that usually speeds the rot out of the boiler. Oil is different, but i'm trying to keep water return temps up above 135F to avoid.
Efficient oil combustion typically is up around 170-180F. The boiler dumps into a big 100G tank, and the honeywell controller uses variable speed injection into a floor loop off the big tank to control the floor temp to the desired temp. While it doesn't have a slab sensor, it does have outdoor reset and none of that functionality is included in my controls. I'm only handling the burner / waste oil portion.
I'll upload some current photos tonight, but i think some changes are in order. For the oil dripping at a minimum.
Steady state burn will take a bit more tuning of the burner section, and watching times closely. The ideal conditions aren't always the same. I was able to watch the burn and tweak oil flow and air pressure from the cam last night, and once i have that worked out, i'll do stage program on the plc where it will step thru the ideal conditions for the burn, once that's done,
it should be pretty automatic. Barring equipment failures anyway.
Once i get that part done, i'll do full auto heat while i get the new boiler manufactured. I think long term that's the only thing
that's going to fix it. Since the burner tube GLOWS RED during operation. And that's right out in the open. I need all that burner tube to be internal to the boiler and it's not going to happen on this 1930 Kohler.
