Sparkynutz
With my current garage project I figured it was a good time to add a garage door on the side wall. I live on a corner and would like to eventually put a driveway from street across my backyard to it.
Until now I've only used 16ft wide garage doors and parking my truck in the standard 9ft wide x7ft tall door on my new house attatched garage is more nerve racking than I'd like so I plan on putting in a 10ft wide door for quicker parking and easier drive through to 16ft door on end wall.
While I'm at it I figured I'd try and future proof and also as a selling point some day put in a taller door. A friend of mine complains all the time that his lifted truck won't fit in his garage. An extra foot taller door would make a world of difference for many reasons.
I'm pretty sure I won't have a problem but figured I'd ask if anyone has done this and get input.
Ceiling is currently unfinished but will eventually get some type of covering and blow in insulation.
Sill bottom to roof truss bottom is 109-1/4"
Sill bottom to soffet is 98-5/8"
10ft wide x 8ft (96" R.O.) tall garage door
I have some 11-3/4 " x 24' LVL beams from my garage raise project I will be cutting and using as a header.
Should I rip beam to get proper height or should I remove bottom 2x4 of double top plate and leave beam as is or just leave both as is and just lose 1.5" rough opening size.
I plan on putting garage door where window is and move window between man door and new garage door.
I have more than enough lumber and jacks to support the side wall when installing the LVL as I currently have the whole garage lifted no problem.
I'll support on each side of where garage door is installed and also up in and accross trusses supporting roof.
