9HP Honda Contractor Air Compressor $1599
CompressorPros.com
SC
If anybody needs a great portable air compressor, this is a deal. Normally over $2000.
This ships factory direct and comes with a 1 year warranty.
BelAire TH908
  • 9 HP Honda
  • Recoil Start
  • 2 Stage Pump
  • 18.5 CFM @ 100psi
  • 175 psi Max Pressure
  • Engine Slowdown
  • 2 x 5 Gallon Twin Tank
  • Two Wheels in Front for Stability
This is a brand new unit that has been sitting in inventory and we have been asked to sell it.
BelAire Model TH908
Only 1 Available
torqueman2002
Tried to post a picture but it is crazy huge.
Here you go.
C
CompressorPros.com
SC
Ok guys and gals...somebody please buy this compressor. I have lowered the price to $1549. Free standard shipping to lower 48. If you need liftgate, it would be $75.
TH908
C
CompressorPros.com
SC
I can't believe that this thing still hasn't sold. Not really a "Garage" air compressor, but great for mobile applications. Just dropped the price to $1459.
TH908
9 HP Honda (Recoil Start)
18.5 CFM @ 100 psi
175 psi Max
2 x 5 Gallon Tanks
Tuscani2718
Upper Hudson Valley
Could this be used in conjunction with a larger tank to paint with? I'm stuck without 220 for the foreseeable future but have some high cfm projects to do.
C
CompressorPros.com
SC
If your air demand is around 14 CFM, you should be ok. Depending on your tank size, it may help cool the air a bit so it doesn't carry as much moisture to the air lines. Some people get these and use them for spraying applications.
Toolhorder
Montana
I don't need a portable unit but my shop needs a real compressor. What do you recommend so I can run a tire machine and high demand air tools like cut off/grinder tools and surface prep die grinders?
C
CompressorPros.com
SC
Is it just you or do you have more people using air? If it is just you, I think you could get by with a "Real" 5 HP unit, something around 18 CFM. We have a bunch in that range. Send me an e-mail at [email protected] with the answer for my question above and where you are located and I'd be glad to give you some options.
