A better junction box?
MushCreek
Upstate South Carolina
I hate having to use a junction box, full of wires coming and going with lots of wire nuts. It just seems hack to me, and hard to modify and service. Instead, could I use terminal strips to distribute power? In an effort to simplify the wiring in my barn, and minimize the number of circuits, I'd like to have about 5 cables in one box. It's just for lighting, which is all LED. The total load, if everything is on all at once is only about 400 watts. I could take a suitable size enclosure, put in three terminal strips, and make nice clean connections, with everything clearly labeled. Would that meet code? Is there a reason (besides cost) why J boxes aren't done this way? Power distribution is done this way in machine tools, and it's so much cleaner.
Dave Nelson
I've never done that in any residential application, not saying it couldn't be done after checking code. I would increase the size of the junction box ( if there is room) or add a extension ring to allow wires to be folded neatly in box.
tyme2par4
NH
As long as you are using properly listed connectors, I don't see any reason you couldn't do that.
As for why it's not standard practice, probably because wire nuts are a lot cheaper and faster.
Bert_
NW Iowa
Why do you need 5 cables in a box? Most of the time it can be designed so there's no more than three cables in any box.
MushCreek
I have different lighting switches that aren't very close together, so I'd have to run power further than coming out of a junction box. I looked at terminal strips at HD, but didn't like them much. They didn't seem to have the jumper strips, or insulated covers.
sberry
Brethren, Michigan
Do it the way it's commonly done. Wire nuts are very good, if it's designed right you won't need to modify it and it won need maintenance.
