Hey guys--
I was hoping somebody here might lend me a little experience before I call a pro. I'm kind of broke at the moment.
I have two A/C units and one seems to be having some issues. The condenser (compressor?) makes a fairly loud hum, louder than the other one at least. The fan doesn't come on when it first starts; instead, it'll run for a short time (20 seconds or so) intermittently. It seems to start okay and the fan motor doesn't make any unusual noises. The bearings are smooth. I am hoping the issue is electrical since both the compressor and the fan seem to be having problems.
The (dual run) capacitor looked fine, but the replacement was $12, cheaper than the tool to test the old one, so I changed that already and got no improvement.
I did notice that the relay (whatever it's actually called--the switch that the thermostat activates) makes a humming noise itself and though it seems to work, today when I went to look at it, it neither hummed nor made contact after I turned on the inside A/C, so I pushed it in with a screwdriver. It stayed in. No change in operation. Tapping the contactor with a screwdriver didn't seem to do anything either.
Should I replace that relay next, or am I off base? Anything else I can check or try myself before calling in the professionals? I do appreciate any help you can offer. New house, no money, you know how it is.
